Dec 16, 2015 #1 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 1,977 Yes I had to pull the ecm wire at the battery to cut the car off and then disconnect the battery . Is it time to change my ignition switch?
Dec 16, 2015 #2 8 87GNSteve Just another pretty face.... Joined Jan 15, 2004 Messages 3,726 Sounds like it.
Dec 16, 2015 #3 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 1,977 Ok thanks would that be available in any auto parts or will I have to order it .thanks
Dec 16, 2015 #4 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,610 or you may need to adjust the lockout rod under the car try twisting the column by the dash counterclockwise
Dec 16, 2015 #5 8 87GNSteve Just another pretty face.... Joined Jan 15, 2004 Messages 3,726 Did you try turning it off in any other gear besides park?
Dec 16, 2015 #6 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 1,977 Did all that and it it in other gears reverse neutral Park ignition key wouldn't even move at all Even put a little WD-40 there But nothing worked got the ignition from Advance auto parts 18 bucks
Dec 16, 2015 #7 G Gene Van Horn Active Member Joined Feb 20, 2013 Messages 947 This is a new one on me,never heard of this happening before. Sorry cant help, maybe linkage problem.
Dec 17, 2015 #8 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 1,977 All done put the new ignition and no problems thanks for chiming guys .
Dec 17, 2015 #9 G Gene Van Horn Active Member Joined Feb 20, 2013 Messages 947 Alrite dude, sounds good thanks for the info,Gene.
