Car was a 484 block, .030 hypers, file fit rings, std/std polished crank, two billet caps, 215/220 roller, roller rockers, Champion Irons, Champion intake, E85, 120's, TT chip, 72GTQ, Balanced, crack checked,reconditioned rods, Lined, etc.
Now as much as I dont want to say, but I have to becuase it plays into the fail points, Austin isnt the best tuner in the world and plays with his stereo more than paying attention to the car so it had some detonation when he was trying to get the bugs worked out. Not that he doesnt pay attention at all but he could have done a little better job at it. One of those issues was that the cam didnt have the oil groove in it and neither did the cam bearings so the drivers side wasnt getting oil to the lifters and smoked a couple pushrods and a couple cups on the roller rockers. So he took the cam in and had the machine shop cut a groove in it. Now after this, we take the car on the Long Haul, had some more knock issues on that trip but ran pretty well. He then started to have some pretty bad issues with the crankcase getting pressurized. He did a compression check and everything was good.
I know Austin well enough to know he had some fun with it after that point but supposedly it was doing well until the noght it just blew the hell out. Like I said, he says he wasnt on it.
Giving Austin the benefit of the doubt on tuning and paying some attention to knock, my theory is that there was a balancing issue with the crank and it eventually just cracked everything under the caps and then gave the crank enough room to wobble and crack. Austin thinks it's the hyper piston #5 that gave out and caused the rod to pull out of the piston and then blow everything else out. I dont think thats the case becuase I've opened up plenty of motors with broken pistons and rods through the side of the block but never seen anything take out the entire bottom end and crack the balancer and front cover, usually the rod just breaks in pieces and windows the block.
Or, I'm also thinking that Austin may be partially right. I dont know how the wrist pin gets oiled in a 4.1 but possibly the groove the machine shop cut into the cam wasnt enough and didnt supply enough oil to the wrist pin on #5. Eventually the wrist pin seizes up and breaks out of the piston??
Or was the pressurized crankcase becuase of a damaged piston skirt, or cracked piston? The piston does have a chunk taken out of the top of it but no pitting and i think the chunk is from getting the beat down once it fell out of the bore.
What the hell would case the balancer to crack in this sort of a blow out? The front caps are still intack. Or did the balancer give out and then cause this whole thing as mentioned earlier?
