SignUp Now!I concur- balancer was the start of this apocalyse.Balancer broke, crank went into a "speed wobble"?? The rest is history. I'm betting this didn't happen "just driving along".
Broken balancers are not uncommon. Bal loose, then cracked, knocked timing out of whack??
All the 4.1's I've seen had rolled fillet crankshafts not the standard N/A cranks without rolled fillets on the rod journals.
Neal
What does the keyway on the crank look like? The balancer looks like its beat open like it was loose.I cant see it doing this kind of damage.My buddy drove a mustang for 150 miles with a seperated balancer and It didnt do any damage except for the timing cover. Have to see the bearings. Doesnt look like anything starved for oil. Nothing blue from what I see. That sucks .
What a mess...sorry to learn of Austin's bad luck. I would assume a "resurrection" is planned?
Right, the crank was turbo crank but what I was saying is the motor was a regular 4.1 that was ran with a carb (N/A) prior to this build.
Yeah, you know we will get it back together. Not sure what he's going to do now. I think he's scared of the 4.1 now so he'll probably go with a 109. Either motor wont last when it's untuned though.
HelloBozos said:Did this motor run a Intake pressure equaling Power Plate,or was all the PSI forced down the rear two cylinders the whole time?
The fastest of the fast don't run plates.
HelloBozos said:Because they can tune out the rear lean out,there's different types of plates for different applications now,http://rjcracing.com/product/airflow-distribution-plate/, I was just curious if "This" motor ran one. either it did, or didn't....most likly wouldn't of changed the out come
Usually the front leans out![]()
