I have an unexpected problem with the crank that I noticed when trying to degree the cam. I kept getting very strange ICL numbers and at first it was purely because I did not know how to set up the timing chain and gears (TA Perf. 9 key timing set).
But when I got the instructions for the timing set I noticed that when I bring #1 cylinder to TDC the timing marks do not line up and crank key is not pointing to 2:00 o'clock. At TDC it is at 1:00 o'clock. In both of the pictures #1 is at TDC, and you can see how off it is.
Has anyone experienced anything like this? I wish it would be just a user error, since this is my first time building a turbo Buick engine.
Short block includes 109 block, CAT stock stroke crank, TA Perf. balancer, K1 rods, JE pistons. Comp 214/210 roller.
