What Bison said is what you need to understand but unfortunately it is not easy to understand
In a turbo motor there is a lot more to it than head flow and there is VERY little information out there on it especially when it comes to cam profiles. In a turbo motor understanding compressor maps how it relates to engine efficiency and rpm make a much bigger difference in performance than head flow. Good case and point a max port TA or GN1 head can reach 280-300 cfm, an average S2 can get 320-340 on intake. Take your avg TSM combo with a 70mm turbo and I would almost bet the car would slow down with S2 heads, regardless if it didn't slow down it definitely wouldn't be any faster.
In TSO where we can run a much larger 88mm turbo this has been a debate we've had for many many years. With a larger turbo the better S2 heads should be more efficient at higher rpm thus allowing the motor to extract more power from the turbo, or so it would seem. The times in my sig were run with GN1 heads in TSO trim.
