Champion, h & r, caspers, gm nos, stock parts
Hot Wire Kit Sold
Payment recieved for Caspers Hot Wire Kit from Arturo.
Payment pending on the Champion Altenator Bracket.
Everything else is still available.
What about the A/C compressor? I want the one with the correct pulley..
A/C Compressor Sold
Payment received for the A/C Compressor with the correct pulley.
Payment received for Caspers Hot Wire Kit from Arturo.
Radiator Hold Down Picture
Here is a picture of the radiator hold down. It is in good shape but not perfect. Let me know either way. Thx
lots of 86-87 turbo buick parts
champion, h & r parts, caspers, stock parts
prices do not include shipping
paypal available and preferred
champion, h & r parts, caspers, gm nos
champion 1 1/2" plenum spacer new in box (w/gaskets) $80
champion 1 1/2" plenum spacer w/6 vacuum ports (no gaskets) $85
champion altenator bracket no a/c & no power steering (new) $150
h & r parts poly transmission mount for 200r4 (used) $75
caspers fuel pump wiring harness upgrade kit #102028 (new) $40
t-top weatherstrip seal gm nos qty 2 (new) $50 ea
a/c compressor gm nos (new) $195
direct scan tuning software box w/cables (win98 laptop needed) $100
heater box with no a/c (nice) $250
gm maf used (not aftermarket) $95
pinion snubber aftermarket (new) $35
pinion snubber aftermarket (used) $20
motor parts
coil pack complete fits 86-87 turbo-v6 (used-tested good) $95
coil pack bracket horseshoe (used) $45
radiator hold down stock (used) $40
battery hold down stock (used) $25
fuel rail stock (used) $45
up pipe stock (used) $30
engine hoist bracket stock (used) $25
main accessory bracket stock (used) $75
altenator bracket y-shaped (used) $30
a/c compressor bracket y-flat (used) $30
timing cover stock (used) $45
valve covers stock no filler (used) $45 set
oil dipstick and tube (used) $50
transmission dipstick and tube (used) $45
oil pan 86-87 v6-turbo no pickup tube (used) $50
oil pan pickup tube (used) $40
pulleys stock used (assortment of pulleys) price varies
heads 8445 stock unported (used) $75
rods (2 dot) & pistons (0.030) stock (used) $50 complete
intercooler stock (used) $50
radiator fan stock (used) $40
driveshaft stock gm (used) $50
egr stock (used) $20
egr plastic cover (used) $10
exterior
quarter windows blackout very nice (used) $125 set
t-tops locking w/out plastic trim (used) $150 set
rear bumper support aluminum $95
tail lights black $150 set
tail lights chrome $125 set
headlight bezels black w/side lights $125 set
wiper arms metal color nice $50 set
license plate holder metal $10
rear center filler for license bracket $25
body and door aluminum trim painted black no rubber insert $100 set
headlight trim metal holds headlight in place $15 ea.
Wheel well trim black driver front only (3) $45 ea.
Wheel well trim chrome passenger front only (1) $40 ea.
Wheel well trim chrome passenger rear only (1) $40 ea.
Windshield trim blackout 3-pcs $60 set
rear window trim blackout 3-pcs $50 set
trunk trim black $75
interior
center console gray no shifter, no base, no plate (excellent) $275
guage pod a-pillar single gray $20
t-top trim for locking t-tops passenger side only (nice) $50
third brake light gray (used) $30
door pull gray (1-set, 1 extra) $15 ea.
Door pull maroon (1-set) $10 ea.
Door panel lower gn concert sound passenger side only (nice) $75 ea.
Door panel lower gray concert sound (1 small hole in bottom) $125 set
door panel lower gray no concert sound $90 set
door panel lower maroon no concert sound (1-set, 1-pass) $80 set
door panel upper gray (2-sets pretty rough) $60 set
door panel upper maroon (1 set) $60 set
dash gray (i have 2 but they have splits on top edge) make offer
interior gray plastic parts (i have most of these parts available)
interior maroon plastic parts (i have most of these parts available)
pictures available on request
i already have pictures of most all of these parts ready to go.
the part is not sold until the payment is received!!!
if you have any questions please feel free to private message me.
interested in the gm maf and taillights black and headlight bezels with corner lights please pics thank does ma work thank you.
Looks good, I will take the headlight bezels/side lights, let me know how you want to do payment.
GM Maf, Tail Lights, Headlight Bezels
ALVAROG1983;interested in the gm maf and taillights black and headlight bezels with corner lights please pics thank does maf work thank you.
The GM Maf is good and works great with no problems. There are some pictures of the headlight bezels in an earlier post. I will send you pictures of the maf and black taillights to your email. Sent PM.
hi there. i'm looking for a somewhat complete set of engine/accessory bolts. maybe from a parted long block? Decent condtion. thanks
I'll take these if still available?
T-Top Weatherstrip Seal GM NOS Qty 2 (new) $50 ea
Take paypal? Total with shipping to 75094.
Thanks,
Dannyo
