Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
I've put a complete Regal Digital dash in my car while I painted it earlier this year. The numerals were garbled and I couldn't read a thing. That got me looking at aftermarket gauges that are compact and may fit into the original opening. This unit is little longer than the stock cluster and will take a small amount if work to get them to fit. In the end I thing it will look factory. I'll also be able to keep all the original idiot lights! Here's what I decided to buy:
Here's how big it is compared to the stock unit and how it will look once installed.
http://members.cox.net/turbomalibu/misc/gauges/P1030583 (Small).JPG
http://members.cox.net/turbomalibu/misc/gauges/P1030588 (Small).JPG
What it has:
VFD3 Control Box Designer Series 6 Gauge System for 3” x 10” Opening, 0-255 MPH Speedo, 0-8000 RPM Bar Graph Tach, 0-18,000 Numeric Tach readout, 0-80 PSI Oil Pressure, 0-300 F Water Temp, 8-17V Voltmeter, 0-99% Fuel Level Gauge, and Odometer/Trip Odometer (0-999.9)
Built in Turn Signal, High Beam, Brake, 4wd, Wait to start, Cruise Engaged, Gear Shift Position for Automatic Transmissions (requires optional GSS-1000 or GSS-5000 sender) and Check Engine Indicators.
Also included is a Resettable Service meter (0-9,999.9), 0-60 MPH timer, High Speed Recall, ¼ Mile Time, End of ¼ Mile speed, High RPM recall, and RPM warning which flashes “SHIFT” when exceeded (selectable from 2,200-14,800 RPM).
Fully metric systems available upon request with KPH speed reading, degrees C and 0-100 KPH timer.
The System Includes Automatic Night Dimming and User Adjustable Warning Points.
Kit Includes Oil Pressure Sender, Water Temp Sender, and Speed Sensor. Does not include Fuel Level Sender- the unit is adjustable for the following sending units: Stewart Warner 240-33 ohm, VDO 10-180 ohm, GM 0-30 ohm, GM 0-90 ohm, GM 40-250, Ford 73-10, Ford 20-150, and has a Custom setting to program nearly any alternate range of OEM fuel sending units.
http://www.dakotadigital.com/
What it has:
