blackgn231
Money pit
- Mar 28, 2007
I know you can use a straight ruler when doing it as the machine shop but whats the min on the feeler Gage what should not be able to slide under?Also any thing special,I should do before putting heads back on ,used brake clean on the heads to clean oil and grease off should use this on the block also? How long should you wait to re-torque them?
			 )  Torque the head bolts (ARP) in four steps starting at 40 ft/lbs. then 50, then 60, then 70.  Let sit for aprox. 20 minutes then loosen each bolt and re-torque to 70 one at a time in any order.  Be sure to use thread sealant on the threads and add ARP lube to both sides of the washers.
