Chris,
Drilled the .060" hole in the governor cover..
Went from a 5200 rpm shift to a 6800+
Damn...
Thing would not shift at low throttle, even with the TV backed WAY off.
Put the un-modded cover back on and things are back to normal.
Question for ya...
Can I slow the band knock-off by using an orifice cup plug in the servo passage?
Still a very slight cut-loose at WOT even though I drilled the 3rd feed holes.
I also used one of your suggestions for the park pawl linkage rod cut-out...
Damn...
Question for ya...
