code 22 and 24 on scanmaster
BLKCreeper
Alright well the car has been apart for about a month now and I had to codes at the beginning. Since then I have replaced exuast, dp, adj fuel press reg., ta49, rjc powerplate, cleaned IC, intalled fp guage, new y fitting, and replaced a bunch of hoses..Now the code says for either one I cant remember, but one dealing with the TPS, and the other dealing with the spedometer cable.. I touched neither of those. The only thing that I can think of is when I started the car up that some of the no seize burned off and Hit TPS and made it go bad, but it was giving me this code right from the start. I dont know, Help much appreciated as usual, THanks guys. Caleb:confused: :mad: :confused:
Disconnect the ECM power wire (orange) and see if they return! I had the same code happen on me and reset them and they have not come back.
