There is a sticky blue substance between the coil and the ignition module. Is this normal? Is this some sort of heat sink? I can actually see the terminals on the top of the ignition module where the connector is.
There is a sticky blue substance between the coil and the ignition module. Is this normal? Is this some sort of heat sink? I can actually see the terminals on the top of the ignition module where the connector is. View attachment 172090
That is not normal. That is an indication of a very bad ignition module when that happens.
If you don't belive me take the module to your nearest auto parts store and have them test it for you, most of the larger auto parts chains can do that.
Glen from www.NOS4GN.com will take care of you and probably be cheaper too... he also supports our forum and is a nice guy. Cannot beat his customer service.
