Cometic question
EVIL
BANNED FOREVER
Lets say you installed cometic head gaskets with the copper spray and within five minutes of having torqued them to 85lbs you have to take a head off.
Is the head gasket now compromised since it has been crushed to spec or will re spraying it be fine?
I believe it has been compromised but i must ask before ordering a new one.
D
Considering I took mine off after thousands of miles and put them back on after a motor rebuild I think you'll be fine.
re spray ... say a word of prayer to the buick gods an u will be fine
Sooooooooo save the $90? alrighty then. I'm not one to pray but . . .
Apparently you guys are the buick gods.
thank you
D
As long as they are going back on the same block and heads (not changing mating surfaces) I have seen guys use them multiple times. A friend of mine with a low 7 sec turbo BBC reuses his often, multiple times.
Have you confirmed the head RA (roughness average), because I wouldn't even bother re-installing these unless you know for sure your heads are at least the 50RA Cometic calls for.
Wouldn't the copper spray take care of the roughness issue?
D
Didn't on mine, was too cheap to have the heads looked at and figured the MLS aspect would make up for any head smoothness issues = poor loses again.
I've feed my system so many GM tablets it's breath will be fresh for decades. ;)
Can you translate that to English please?
D
He is saying he had the wrong surface on the heads. We have had them on a lot of engines and heads that didn't have the right "finish" on them. Still worked fine BUT as everyone knows our parts are special :p Spray yours an put em back on . :cool:
he is saying he had the wrong surface on the heads. We have had them on a lot of engines and heads that didn't have the right "finish" on them. Still worked fine but as everyone knows our parts are special :p spray yours an put em back on . :cool:
lol! X2
WTH, how wasn't I clear, get the heads looked at for RA, if not, you can end up like me and a bunch of others that HAVE LEAKS OR IT DRINKS A BUCKET OF COOLANT. That clear.
Better yet, do a search for "Cometics Leaking" and tell me what you find. :rolleyes:
Oh, you'll find 70 threads about Cometics and some concern towards them leaking.
If you can find Hylomar in an aerosol can, I prefer it over the copper spray. Also, where are you finding the Cometics for $90? If that price is correct, I will be stocking up.
I've re-used Cometics and used a thin coat of high temp RTV and havent had a problem with them yet. They are designed to be re-used.
Crystal clear.
I'm only addressing the OP's question, reusing a headgasket and what issues there might be regardless if I like them or not. I don't think Cometics are junk but I have seen they are more prone to leaking on GN's than most cars so I'm going to pass on info I'd want to hear if I could go back in time.
FWIW, I have a set of Cometics on my Talon that take 30psi very frequently and for years have been leak free. They're great on Imports at least. :cool:
