Connection near power steering reservoir
realspartan
Hi guys,
I noticed yesterday afternoon that there were two wire that were not plugged into each other on my GN very close to the power steering reservoir. I pluged the wires to together and now my RPM gauge does not worK. Does this make sense? One of the wires/connectors was green. Please supply some info...
Regards,
Realspartan
Unplug..
Hi guys,
Regards,
Realspartan
them. 1 is the tach signal, and the other is a fuel pump power connection. Neither is used, unless:
1. You have an add-on tach, and need a signal.
2. You want to "jump" the fuel pump, to drain the tank, or make some tests.
yup...plug the wires together and it kills the tack ... so you may want to disconnect them :p
