The highest quality valves are manufactured on SWISS CNC SCREW MACHINES. What many have failed to realize here is what happens in low /low 2 and reverse ranges when larger boost valves are used. It has been covered before. Additional mods must be made elsewhere or pressures in these ranges get screwy the bigger the boost valve is. I have not found the blueplate to be any better in the 2004r than a stock or red raybestos clutch in the 2004r with conventional direct clutch flow paths , however I have not tried the blueplate with a dual feed direct clutch because of my success with what others may believe to be a clutch plate of lesser quality. Dual feed works and should be used in conjunction with the information/tech given to the industry in the form of a deleted 3/2 control valve . The real benefits of the large boost valve is the increase in pressure rise at lower throttle angles. The .555" boost valve is the clear winner overall. The tight fit into the reamed pump bore eliminates loss of torque signal oil to the valve at running temp, a real cause of pressure loss related failures in the 2004r.
