1BAD_GN
1BAD_GN
- Nov 28, 2012
Just purchased my first GN(87), its bone stock. I would like to upgrade cylinder heads and camshaft, preferably a hydraulic flat tappet, any suggestions??
SignUp Now!I never would have built my motor had I not blown a hg. I'd start slow and leave the motor stock for awhile.You may want to do a lot of info gathering before you do anything to your GN, especially since stock GN's have been into the 10's [500 HP] with un-opened factory engines, just the PROPER add-on parts for performance and reliability.![]()
No E85 in my areaIf the chip is burned for it. Yes? Do you have E85 in your area?
throw an alky kit on it and call it a day
Thanks Nick. I want performance to be in the mid 11's nothing to radical and still be a pleasure to put my wife in it and take a cruise around town. Not to mention, having a sleeper for the unknowing!!In my opinion, this is NOT the first thing you want to do?
An alky kit can work well especially on a street car if all else is working as it should, and you must have ample fuel supply.
The weakest item on a stock GN is its fuel delivery system. The stock fuel pump is marginal at best even 25 years ago, and even less than adequate now.
Alcohol injection is used to cool the intake charge in the combustion chamber, and will allow more boost for more power. When you increase HP, you must also increase fuel and air into each cylinder.
So first you need a pump and regulator to provide more fuel, and a chip to manage fuel delivery and other parameters for a safe, reliable increase in power.
I have repaired many stock GN's because new owners just added parts which were not compatible with the build, or each other.
The factory did an excellent job providing us with a great combination, and after lots of screw-ups, we have learned what works when adding and changing parts for increased performance, and what NOT to do!
You should define a performance goal, then find a build to fit that, and your budget, not just throw random parts at it.
Scooby that 11.5 @ 121 is EXACTLY what I'm looking to achieve.Good advice from Nick. Cover the basics...first.
