hemi8
Goin Sideways
- Jun 6, 2001
Finally, after 2 months of oil spewage I figured out what was wrong. The 2 bolts holding the crank sensor bracket on were the culprit. I did not put any sealant on the threads because they were not going into the water jackets. On thing though, there is oil splashing around in there and it was racing by the bolt threads, spewing onto the driver's side oil pan rail, crusing down the oil pan rail and collecting at the back corner of the oil pan and dropping onto the crossover. It looked exactly like a oil pan gasket or a rear main seal. I did trace it to the front cover but could not figure out where it was coming out. Anyways, hope this helps someone. Lesson learned, coat ALL the bolts for the timing cover, not just the ones that go into the water jackets, but what do I know, I was just following what the BUICK Power manual said to do.
Mike
86 GN
Mike
86 GN
