Alaskabuick
- Jul 4, 2004
Anyone running this turbo on the street with any feed back? How is responce and where does it hit?
Den
Den
I think it is really hard when talking converters about what stall, because I have found that each converter stalls a different, usually lower than what I ordered. Or is it just me?
Dennis
I had my "O" pump Vigilante restalled about a year ago. It was suppose to rpm about 3700 to 3800 but my engine can stall that thing to 4500 at 15psi of boost.I have replaced it with another one that stalls much less....at 15psi it now goes to 3700 with my 70GTQ with .85hsg. Unfortunately, I don't know the part number for it.
There is almost no in between converter that would be acceptable for a turbo like that. You are better off going with the converter that will make it spool fast and running an electronic boost controller with CO2 to maximize the spool/vs tire spin on the street/track. If you pick a converter that wont blow the tires off it will be a dog out of the hole. I would go with a 3500-3600 stall at zero psi if an 8:1 231ci engine with an aftermarket ecu. A 3400 would work if the engine was 9.0-9.5:1 compression with the aftermarket ecu. A solid 4000 stall at zero boost would be needed for a non BB version of the 70GTQ to get it going. The 70GTQ needs to be over 5200 rpm at 24-28 psi on a 231ci to be most efficient.
I should send my converter in for a re stall...looks like I am out in left field based on this info.![]()
How about giving some "USEFUL"information for a change instead of being a smartass! AS USUAL!
respectfully,Nick
I am learning some valuable info from this "USEFULL" thread keep it coming guys!
