The RMI-25 will clean out your cooling system while you drive. Check out their website:
www.RMI25.com
www.RMI25.com
SignUp Now!So, Nick, what you're saying is I can put the RMI-25 in WITH Prestone antifreeze with no problems and it'll run cooler? .....................
As to a 50-50 coolant mix, should I used distilled water, tap water or spring water? Our tap water is run through a water softener system since lots of minerals are in our water table out here in the sticks, so we used bottled water to drink,...........
So, help me out here, Nick, what's the correct water should I use? I have always trusted your judgment.
Thanks, kindly.
Bruce '87 Grand National
Ok the dexcool is going in the trash. oops sorry "properly disposed of"
