My 60k GN,I rebuilt motor/trans in Oct/Nov 07. Trans is a stockish rebuild with CK kit,wide band,teflon rings,3 od clutches, PTS servo,Art Carr pan and 9x11 convertor. It has maybe 800 miles on it. Trans has always shifted great. I noticed the fluid was starting to smell burnt. I dropped the pan and found very minimal bushing debris,and the usual black coating from the band/ clutches. I can't see forward,direct or the inside of the band,but lo rev and OD look ok. The band has play and should not be dragging. I built this unit with CK's book and did all his mod except dual feed. Trans has no billet parts.
I have not added a big cooler yet. I am thinking I waited too late
I added alky 3 weeks ago and have 23-24 lbs of boost.
I changed the fuild and filter. I am pretty sure somthing is already hurt since it smelled like that. But time will tell. I may pull it out when I get a spare trans togther.
