Jan 15, 2016 #1 F flyhigh Member Joined Jul 22, 2014 Messages 56 t type would not start no fuel pump gray wire would turn pump on car started went to f p relay on fender jumped center pin /pin in middle drove home thanks again no tow truck Earl
Jan 15, 2016 #2 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 And this is why i still have my pressure switch connected and never leave home without my AAA card.
Jan 16, 2016 #3 B BOP4ever Member Joined Jul 6, 2007 Messages 892 What do you mean by have pressure switch wired up? What pressure switch? How does it help?
Jan 16, 2016 #4 B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Messages 16,740 Oil pressure switch. It will bypass the fuel pump relay when it sees like 8 to 10psi of oil pressure.
Jan 16, 2016 #5 F flyhigh Member Joined Jul 22, 2014 Messages 56 how long can I run jumper relay 5 day commin
Jan 16, 2016 #6 B BOP4ever Member Joined Jul 6, 2007 Messages 892 Figured that was it. I think mine was removed to screw in the sender for the gauge. May need to T it in and put the switch back !
Jan 16, 2016 #7 T TURBOPOWERED68 David Joined Jan 31, 2006 Messages 8,819 I have two OE "T"s in place keeping the pressure switch and the gauge sender
Jan 17, 2016 #8 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,084 flyhigh said: how long can I run jumper relay 5 day commin Click to expand... As long as you want.
