Hi JERRYL,
I'll try answer your qestions as best I can. I know this won't make it easier and you die hard guys are going to slaughter me on this but unfortunately we don't have a lot of data. The car is mostly stock other than: The block was decked and bored .060, heads milled, and cam upgrade. As far as I know we still have OEM ECM, turbo, etc...
1. We only have the OEM boost gauge and it doesn't work, so I have no idea. (I KNOW, I KNOW)
2. Comp Cams 69-234-4: 206/206 Duration@.050 425/425 Lift
3. The plugs actually looked very good. Even the one on the bad cylinder.
4. All electronics are OEM as far as I know and we were running 93 octane pump gas.
5. Fuel pump pressure at boost? NO IDEA
6. Monitoring for KR? - NO
7. Sealed Power cast dished pistons. Rings? - I don't remember off the top of my head. I know they weren't the cheapest ones, but I don't remember exactly what they were. The rings actually look fine on the outside. I haven't pulled them off the piston yet to check the inside.
Where do I get PowerLogger? I'm a technology guy by profession (nerd by day, grease monkey by night) so I'm sure I can handle it, but I've never done much "techy" stuff on a car. Honestly most of my engine experience is from racing an asphalt late model and we don't use much technology there.
I don't have any pics right now, but I'll get some done and posted soon. THANKS FOR THE HELP!
I think it is pretty neat that your son wanted a GN instead of a Honda or something with a SBC and we all want you to succeed with this project!
The melted piston is more than likely from detonation and to find the “why”, good data will be crucial.
As far as “slaughtering you”, absolutely not. It is just that many of us have “been there done that”. Some have “done more” than others . . . . . damage that is. LOL
If you are a technology guy, you will LOVE Powerlogger. Contact TurboTweak and get the PL on an 87 ECM with the right chip. There are people working on these cars with no tech background, and you have plenty of tech and mechanical aptitude to get it done.
ScanMaster is a great tool, but does not have recording ability. With PL, you can record, and with that, you can post a log and we can provide tuning guidance.
Note:
PL® and Scanmaster® do NOT work with the 85 ECM, so you need to upgrade to get those to work. So at this point, I would look for an OTC2000 or OTC4000 monitor. These will work fine for a while but whatever you decide, you need a monitor/scan tool.
You may want to update your location so you can get some local assistance.
Aslo, read the sticky and everything you can about these cars, and post as many pictures as you can of the turbo, etc sowe can get some things verified.
