Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Incorrect. The voltage should drop from 7.5-8v to 0 volts. That's how you set the sensor. When the window is open you have voltage when the sensor moves past the window no voltage thus voltage drop. Don't waste your money on a sensor just yet....those things are expensive. Double check your double check.
I agree.
Not sure if the cam sensor was the problem, here is why. . . .
If the car started, and idled/ran ok, the cam sensor was fine since "No cam signal = no start".
If the cam sensor signal get lost while running, the ECM will go into batch fire mode, untill you shut it off.
