V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
So we've confirmed that this is only an issue with alky?
SignUp Now!So we've confirmed that this is only an issue with alky?
I understood what you said. One and two don't get significantly more air to them. I think they get significantly less alcohol. I think I was very clear about that. If it was getting more air than the others,dual feeding wouldn't be the fix because there isn't a fuel distribution problem. If one is leaner than the rest,it's not because the rail isn't dual fed.You must not completely understand what I posted. If you did, you wouldn't have quoted that.
Focus on 1&2. I you supply them with the same fuel and more air to #1, which will be lean?
The pressure has a lot to do with it too. Go read up on thermodynamics of methanol. You can calculate the vaporization % based on the % of methanol in the solution injected, the inlet temp and the manifold pressure. Methanol absorbs water readily and raises its boiling point. The higher the latent heat the higher the energy absorbtion when it vaporizes. There is no set temperature because the manifold pressure isnt constant and the amount of alky injected isnt constant. One thing ill say is that when injecting over 25gph on a 700+hp engine and the charge air temp is going under 70* you are about to be in trouble. Eliminating the intercooler may be the way to go in some instances.Definitely has me thinking. Temperature has allot to do with it I know. If the charge temp drops enough I can see there being issue with vaporizing. Wonder exactly what temperature that is and how much pressure does effect it. You would think the heat from the blow dryer would supersede but with enough alky I guess it can happen.![]()
Interesting............
The problem isnt about airflow distribution at all. If you ran egt probes you would see that once shutting off the alky you will have much more linear temps front to rear. What does this mean? It means that a % of alky is not vaporized. If its vaporized its part of the homogenous mixture of the of air entering the intake and will be distributed the same way the air is since it is actually part of the air. If its not 100% vaporized it is still liquid which is a separate part of the mixture entering the intake. Guess what? Methanol just like every other liquid has a much greater density than air. Guess what else? Being more dense and seperate from the air it has more inertia. That inertia from the airflow (which increases as engine speed increases, not boost) coupled with the g forces of the accelerating car cause a very high % of this liquid to wind up hitting the back of the intake. Now if you have a wideband correction and are targeting lean you are in big trouble. The more you pressurize the intake the higher the vaporization temp for the liquid. The colder the intake air charge the less likely you are to vaporize the liquid. Too much alky injected upstream is its worst enemy to vaporization coupled with how much is injected. The boiling point for methanol is 149*F at sea level. There is a lot more pressure in the intake at 25-30psi than there is at sea level. Therefore getting a full vaporization on the fuel injected is about impossible since it has such a high latent heat of vaporization. It just drops the air temp so much when a small amount vaporizes that its actually inhibiting the remainder from vaporizing.
Are you guys running race fuel seeing any lean cylinders? Let's say with a proper tune any piston failures?
Spoken like a true chemist.The pressure has a lot to do with it too. Go read up on thermodynamics of methanol. You can calculate the vaporization % based on the % of methanol in the solution injected, the inlet temp and the manifold pressure. Methanol absorbs water readily and raises its boiling point. The higher the latent heat the higher the energy absorbtion when it vaporizes. There is no set temperature because the manifold pressure isnt constant and the amount of alky injected isnt constant. One thing ill say is that when injecting over 25gph on a 700+hp engine and the charge air temp is going under 70* you are about to be in trouble. Eliminating the intercooler may be the way to go in some instances.
