SignUp Now!Sweet6 said:I thought the numbers sounded low to me as well. I was going to try using the math equation as a comparison.
My car was making more power than other cars with DPs, IC upgrades, and other stuff. My car has a GT32, 50s, Fuel pump, and open dump. So I was happy. I think my car was first or 2nd for stock motored cars. Air fuel was 11.8:1 on the best pull. Cars with heads and cam were doing 440HP 470TQ. And had bigger turbos. So I thought my car was about right.
72firebird said:yeah it sounds like your dyno numbers are off because I have a PT51, 42lbs injectors, 3000 stall, RJC PP, and the other normal mods with open exhaust at about 20 psi with 110 running really rich I dynoed 360rwhp 450ftlbs
Sweet6 said:One thing is too, I eased into the gas when I started my pull. That may have affected the numbers. I was more interested in getting the AF dialed in instead of making numbers.
Sweet6 said:What ET and MPH have you ran?
I am going to the track this weekend if the weather holds up. I am hoping for 12.00 @114 or better.
72firebird said:12.2@114 I believe, somewhere around there with a 2.0 60' on Nitto Drag Radials. I'm really dissapointed in the numbers since I think the car easily has an 11.7 in it with some good tires and a little better tuning.
Sweet6 said:I ran my 12.19@114 with about 21lbs and stock TC. 1.79 60' on MT DRs. So our cars seem pretty close. I have since added a 10" Converter and running a few more lbs next time out. I am hoping for 11.80s. Hopefully with a good 60' I can get it.
Sweet6 said:Maybe it was becuase I eased the throttle to the floor on the dyno? I don't know. My car weighs 3500 and I am 230lbs. So figure 3700+ for race weight.
The converter was unlocked. When I ran the 12.19@114. That was with 18 degrees timing and 21lbs. I will dyno the car again when I put my Alky kit on. I will see what the car does then. The next time I will smash the throttle down as soon as I start the pull.
Sweet6 said:I don't know if you saw my best ET in my sig. 12.19@114. So if you car made 400+ going 112. What do you think my car really makes? You know how dynos are??? I see guys with stock turbos saying they made 550+lbs of torque. I do not hold a lot of value in dyno numbers. They make a good conversation piece, that is about it.
Sweet6 said:I see guys with stock turbos saying they made 550+lbs of torque.
