I'm thinking they're different turbos, and different water. Maybe their impellers are some sort of super metal, and they're using distilled water. Who knows. All I know is I've seen many pictures of impellers after water injection, and they were all wore out.
I definitely don't disbelieve you but, if there were such huge gains to be had, why isn't everyone under the sun doing it? I mean, a pump, nozzle, a bit of wiring and a .99 cent gallon of distilled water and bam, double the output... Not seeing it. Grab a bottle of water then grab a bottle of denatured alcohol or meth and feel the difference in the surface temp of its container. Better yet dip your hand in water then dip your hand in one of the latter, see which feels cooler, faster. I fail to see how water beats out meth. Meth cools and can be used as octane. Water can not.
And what about worn out impeller blades? That scares me.
Never saw a mention of it. If you'd like to research it some more go to speedtalk and ENG-TIPS forum and do some searching. ENG-TIPS has a ton of info on turbocharging and it's got people from hot rodders to doctorates that are willing to post info and answer questions. It may be a little more technical than you want but you can find more info than you'll even believe on all types of engineering questions.
Oh no. The more technical the better. I love talking to people with Doctorates, they're a good source of knowledge.
