SignUp Now!You never know maybe I'm about to stumble on something here. Till then my best friends cousins uncles third cousin dropped .4 on his pro stock with a hidden water injection system.So who is actually RUNNING a 50/50 mix thats going fast in a BUICK ?? Never mind your cousin's best friends neighbors brothers SVO![]()
I've got 2 engines I can test this theory on. Send me the turbo and I'll pre-inject water till I'm blue in the face. It has to be a turbo that I can run with the wastegate closed for accurate comparison. A 60-1 would be nice. I don't want to hot mine with a bunch of water though. I'll make back to back dyno pulls at whatever targets/timing you want up until I feel I'm at the edge. Based on the posts I'm reading here it seems as though some are saying pre injecting water will actually increase the size of the efficiency Islands on the compressor map. I'm saying it won't. So anyone who wants to send me their turbo or gift me $300 on paypal I'll run the test. Turbo will be run for all it's worth. I'll refund the $ if no damage to the compressor occurs.
I'm not looking for a donation. Just insurance. I'd be using an extrermely small jet with very high pressure.
what never seems to get discussed on these boards is what goes wrong with things like pre turbo inj.i have seen very expensive superchargers fail due to the coatings on the blades not being able to survive the inj.
Spraying water into the compressor of a turbo charger puts to use one of the most simple laws of thermal dynamics,but at least we know exactly what you're saying. I was unsuccessful at getting Julio to tell us exactly what he was trying to say. What ever the results,I'm guessing you would expect them to be the same on a turbo Buick,a turbo Wankle,or a turbo R2800 Pratt and Whitney or a turbo Briggs and Stratton.some are saying pre injecting water will actually increase the size of the efficiency Islands on the compressor map. I'm saying it won't.
I don't know how many are,but I would think there are some. It's easy to run fast with a Buick with or without injecting a 50/50 mix just before the throttle body. You can run very fast with 93 octane gasoline.If you take that same motor and inject 50/50 before the throttle body,your motor will always be able to produce more power. If you inject 100% meth before the throttle body instead of the 50/50 mix,that same motor will always produce even more power. I understand that you're not asking a question,but stating a well known fact as if someone was trying to dispute this. Were you thinking this was the case.So who is actually RUNNING a 50/50 mix thats going fast in a BUICK ?? Never mind your cousin's best friends neighbors brothers SVO![]()
Maybe I'll be finding out soon. Even if it added 3lbs minute of airlfow by energy absorption at the inlet it will show power on the engines I'm talking about. One was dynoed with a 60-1 and a 6265. There was a thread I created about 2 months ago.The other is a more conservative engine with a lot less valve train and about .5 less CR and an off the shelf 212 cam. Either will be able to show the power of pre injection with no other changes since I'll run them with the wastegate wired closed as a preliminary then I'll add the water pre turbo and see what we get. My thoughts are that I will see a slight reduction in manifold boost pressure and no added power. I hope I'm wrong. Neither the alky or water injected will be used as an anti detonate here. The base fuel will be leaded fuel out of 5 gallon pails.Spraying water into the compressor of a turbo charger puts to use one of the most simple laws of thermal dynamics,but at least we know exactly what you're saying. I was unsuccessful at getting Julio to tell us exactly what he was trying to say. What ever the results,I'm guessing you would expect them to be the same on a turbo Buick,a turbo Wankle,or a turbo R2800 Pratt and Whitney or a turbo Briggs and Stratton.
I don't know if it increases the size of the island as much as it moves it.
I see that we've been reading some of the same info. Did you get it of speedtalk or Eng-tips forums? I've saved some of the info from both of them in PDF but they're so large I can't load them on the board.Spraying water into the compressor of a turbo charger puts to use one of the most simple laws of thermal dynamics,but at least we know exactly what you're saying. I was unsuccessful at getting Julio to tell us exactly what he was trying to say. What ever the results,I'm guessing you would expect them to be the same on a turbo Buick,a turbo Wankle,or a turbo R2800 Pratt and Whitney or a turbo Briggs and Stratton.
I know this was the question that the thread starter asked,but I don't think anyone replied that 50/50 before the throttle body would out perform 100% meth before the throttle body.
If I listened to to all the water injection proponents, methanol would have never been part of cars.. we'd never see a 9 sec Buick on pump gas. They would all be stuck in the 12's or hydrolocking the motors trying to get into the 11's.
I see that we've been reading some of the same info. Did you get it of speedtalk or Engforums? I've saved some of the info from both of them in PDF but they're so large I can't load them on the board.![]()
I think I also acknowledged you as being one of two who introduced this to the TB community. Do you believe that? No power gain on a Buick. 1,800 hp gain on a R2800.I guess it bears saying again.
It's an apples to oranges comparison. I wonder how water is able to lower the temps of a house fire?
Send me the insurance $ and I'll get real numbers.
