Nick McCardle
- May 26, 2001
So, I've got an appointment at the dyno tomorrow just to see what the old brick can put down before I start going to the track this season.
Here are the "meaningful" (I guess?) mods you might need to know about. Motor and transmission are basically stock rebuilds with low miles.
TH 3" Downpipe, K&N Filter, 3" MAF Pipe, Precision PT54 Turbo w/ HD Actuator
Big Neck Intercooler, EBay Catalytic Converter, ATR SS Crossflow Exhaust, QTP Electric Exhaust Cut-Out (partially open)
MSD 50lb Injectors, Adjustable FPR (about 46psi line off), Walbro 340 Fuel Pump w/ Casper’s Hotwire Kit
Hypertech 160* Thermostat, Comp Cams 980 Valve Springs
Vigilante 9 ½” L/U/Single Disk/3400 Stall Torque Converter
110 Gas
TurboTweak 110 Octane Race Chip (27*/29*), Converter Locked at WOT
Here's my tune (May be slightly odd, but I like it)-
WOT + 20.3% fuel in all gears
WOT 1/2 + 0.7* Timing
WOT 3/4 + 1.1* Timing
Boost stays right around 25lbs
o2s around 780-800, showing absolutely zero knock
Take your guesses, I'll post numbers tomorrow.
110 Gas
