- Dec 15, 2002
Few updates
1) Siemens doesn't sell o-ring retainers just in case a few of yours crack like mine did. ooops. No leaks though so all good.
Base pressure went up a few lbs probably from the filter being totally clean, but......
Pressure still isn't close to 1:1. So I'm going to go into denial and will call Accufab and see if there's a chance the regulator can be the cause.
Then when this doesn't help it's onto the intank 044 with custom outlet fitting in stainless. My goal is to make that pump a plug and play with the Racetronix harness and without the sock and with a smaller custom 12mmx1.5 to 5/16th outlet fitting, this should just fit with a small bit of fuel pressure hosing.
BTW, the intake fuel pressure hose is 5/16th ID correct?
