SignUp Now!Plenty. Your duty cycle will be less than 70% to hit that goalWell I have a goal of 10.99 will the 120s and twin racetronix pumps be enough? Combo is champion irons, champion intake, 212/212, pte 6466, etc. Stock bottom. I plan on running around 24/25 psi but I will turn it up more if needed.
YepShould be less than that even.
People are running 30 lbs of boost by spraying a relatively small amount of alcohol on top of the 93 octane gasoline that their engines are running on. What does the alcohol do that allows this kind of boost. Does it increase the octane of the gasoline up to 116?How in the world are people running 35psi on 100 octane? and dont say cooling effect.
Of course you are. It's very obvious. The other obvious thing that you are doing is completely dismissing what cooling the combustion chamber allows you to accomplish. I'll ask again. What does the alcohol that people spray on top of 93 octane gasoline do to allow the high boost numbers and big power production that we see in the turbo Buick community?Im talking straight E85.
at least 116,i have pumped enough meth/water in where the only limiting factor is the ability to make more boost.never found a knock limit.cooling must have a huge impact,perhaps the weight of the fuel may contribute.People are running 30 lbs of boost by spraying a relatively small amount of alcohol on top of the 93 octane gasoline that their engines are running on. What does the alcohol do that allows this kind of boost. Does it increase the octane of the gasoline up to 116?
It certainly must. Even when we run straight gasoline,we inject more than the engine can burn to cool the combustion chambers.cooling must have a huge impact
I ran a 10.99 with 120's, and my DC was 65% and still a bit rich.Well I have a goal of 10.99 will the 120s and twin racetronix pumps be enough? Combo is champion irons, champion intake, 212/212, pte 6466, etc. Stock bottom. I plan on running around 24/25 psi but I will turn it up more if needed.
