Take some of the good, and put it in a glass, and pour so. E of the Lucas Ethanol stabilizer on it, and see what it does. My tester had a white residue on the glass similar to calcium from water, and the Lucas stabilizer cleaned it instantly
SignUp Now!In my case,getting rid of all oil in the intake manifold eliminated it.Anyone have any updates on the black goo? I have fallen victim now too.
Based on what I have seen and heard you guys are in for a bumpy ride with e85.setting the car up to tolerate it and staying on top of the fuel system will be very important.
Same with me. I use a paper filter.Going on my 5th year, and haven't had one issue. I cut the fuel filter open for inspection, and have had the tank out a couple times, and everything looks great. Smooth sailing here
Thats good to know.do you drive it a lot or does it sit?Going on my 5th year, and haven't had one issue. I cut the fuel filter open for inspection, and have had the tank out a couple times, and everything looks great. Smooth sailing here
I've been using Stabil 360 for 2 years. I took my injectors out today to see what they look like. The little bit of deposits are sticky just like e85 is anywhere where I find it and it has dried. Again,for me,getting rid of all oil in the intake stopped my injectors from building up great amounts of brown goo.View attachment 305624 View attachment 305625 View attachment 305626
I used gasoline and it came off with ease. When I used to run gasoline,there was never anything on the injectors. This little bit of deposits is nothing and the engine runs flawlessly. I'm going to switch to Lucas and see if there is any difference.Curious to see if you take some of the Lucas Stabilizer on a rag, and wipe it on the injector if it will take the brown spots off?
