SignUp Now!You will notice that the exhaust pressure will be much lower compared to manifold pressure at the higher altitude if you are measuring backpressure. Shaft speed is much higher at altitude to generate the same manifold pressureThanks for the tip. I'll be rebuilding the engine with better heads, cam and new turbo this winter. With the thin air it really changes the turbo air flow.
