Someone help me understand this I have a stock stroke Eagle crank and a set of King Main bearings with a RJC Girdle fresh back from the machine shop ,Went to install the crank and tighten the mains and the girdle and it spins alittle tight , took it apart and checked everything and it looks like the side of the bearings are rubbing on the radius of the journals, how can it be hitting there if I have about .0008 thousand end play back and forth?? was told thet I need to chamfer the bearings
