RmvBfrFlght
 - Sep 28, 2007
The EBL SFI-6 ECM as delivered won't (shouldn't) have the wastegate code in it. It's been a while, but if IIRC, I either emailed the update to you or you had it from a friend you are helping out. The update is a Windows program that updates the firmware in the ECM. Along with a newer ECU/XDF file that has the wastegate parameters.
To see if the EBL SFI-6 ECM has the wastegate code, either run the engine or do a playback in the WUD. At the bottom of the main display the ECM firmware version is shown. V1.0 is the non-WG version, V1.1 has the WG code.
This is an area we are still working on. I've been finding that the stock WG solenoid doesn't have a lot of range. So the size of the orifice in the Y connector is important. Once the exhaust leaks were fixed the engine started to over boost. Increased the orifice to .028" and it wasn't enough, drilled to .038", and it is too much (low boost).
RemoveBeforeFlight
RemoveBeforeFlight
