SignUp Now!Meziere makes one for buick motors,I run one and its fine on the street,and fantastic for coo l down at the trackNOT FAST said:Just wondering if there is an electric water pump available for a stage motor? if not what kind of water pump are you guys running to keep your stage motor car cool on the street.
............if not what kind of water pump are you guys running to keep your stage motor car cool on the street.
No electric pump will flow as much water as this direct replacement mechanical TA pump at RPM. :biggrin:
nick,
after reading the description on TA's site, dont you think that it sounds a bit weird that the test car ran at 230 deg. until this pump? Not to discredit TA's new pump, but i have never seen a TR idle at 230 unless there was a major malfunction . the only time i have seen temps that high is when i forgot to put my electric pumps fuse in.
Who's to say the test car was a TR? This pump also fits 350 Buicks. Maybe they tested it without turning on the electric fans to see what the pumps would do/could do. Not sure, I wasn't there. Hard to say because the TA blurb is not very descriptive, but it is not a magazine tech article so I am sure they cut it short.
I really do not buy "They move just the right amount of water for maximum heat transfer", at least in our turbo engines?
We run our street cars here in the summer w/o a t'stat, and they ALWAYS run cooler.
