A load on the engine would be nice, but just having the ability to run the engine is invaluable!! Leaks? fix them before install, other problems? Fix them too.
I have lots of "extra" parts like intercoolers, brackets and turbos. Finding enough spares to assemble this rig wasn't a problem. We can now test an unknown turbo for seal problems (oil consumption) by running it on a known engine. Yes, we can't load it up and spin it hard, but that's not the point of this exercise.
The engine is mounted on a BOP stickshift bellhousing that bolts to the back of the stand. I don't have any other mounting points!!! Just the bellhouse! It works great and the engine doesn't bounce up and down like you would expect. In fact, the stand wants to move very slightly right to left when at a very slow idle. If you ever read the Buick Motorsports book on V6 balance you can see and feel the natural shake in the horizontal plane that the book describes.
The stand is also designed for other engines. The next on the stand is a 496 BBC that is just about done. After that is a 1968 Olds 400 for a 442 convertible. The BBC will need some support from the motor mount area as well as the bellhouse.....The engine is all cast iron and is HEAVY when compared to our little V6!!
