87Turbolimited
- Dec 3, 2009
Ok, I have a stock engine stored for approximately 6-8 years. I am now ready to get it running... My plans are to rebuild the motor eventually, but for now going to inspected.
Motor is not turning fully by hand, only a half turn whether counter clockwise or clockwise then it stops at the same location. Seems like something is holding from turning completely.
Things I done before posting the Thread:
Engine is currently on an Engine Stand.
I primed the oil pump - oil does come up.
I added fresh oil, and new spark plugs.
I removed the valve covers and intake. The rocker, springs and push rod are really dry. I could also remove the heads if necessary to verify if the pistons are seized..
I removed the oil pan and everything seem ok and lubricated.
My Question for you guys:
What can the issue be? Or what else do you guys recommend for me to do?
Thanks,
Thanks,
