Factory Rad Hose Clamps (two strap vs. notched band)?
GNXcess
Senior Member
Anyone know a source to get the original style dual "wire" hose clamps? My upper rad hose was changed to the normal single fat band style with the notches, and I want to return to original. Can't find anywhere.
Thanks!
I just Yahoo'd "wire hose clamp" and found all kinds of them?
The other clamp type you're referring to is a worm clamp.
If you want the exact clamps you might try Brian at GBody...
Good luck.
strike
I'll have to google them when I get the chance. I've been hoarding used ones from the boneyards. The black ones off the turbo hose clamps on a turbo'd Sunbird are a good source but than they aren't the correct silver. The silver ones are usually rusty. I wonder if the imports might be worth looking into. I can remember my old 240Z having nothing but them on it.
