hey, I'm wondering if anyone has come across a particular problem before.
I have the FAST system installed in my car. I had the system up and running on my old laptop with win2k.
I bought a new laptop, and it doesn't have a serial port, I bought a USB/Serial adapter, and set it up to com2, as well I set the FAST to read com2 (the port was not in use). The computer has winXP. Since I've installed the FAST software (CCOM WP) into the new computer (from the floppy disk that came with the system), when I run the CCCOM WP EXE, the splash screen says DEMO MODE, and has a Serial# 0, and Dealer# 1... I try to connect and it says ECU NOT FOUND. I'm not sure if its the new com adapter, winxp, or the fact that the program says its in DEMO MODE. I talked to FAST and they said the floppy might be screwed, and that it shouldn't say DEMO MODE, but its the same copy that I ran before from the original FAST floppy, and it installs perfectly, and runs perfectly, its just in DEMO MODE. Do they all say DEMO MODE until its read the ECU? how does the unit serial number, and dealer Number get updated in the software? I can't adjust the ECU Configuration before it is disabled in my list, and I cannot connect my ECU because it says its not found. Any suggestions?
Thanks,
James
Thanks,
James
