Originally posted by Craig Smith
VE can exceed 100 on an NA engine, but you typically won't see it on anything other than a very expensive all-out racing engine.
Where is your air temp sensor?
Does the timing light match what the ECU tells you the timing should be?
Are you doing your calibrations with the engine fully warmed up?
Also make sure that the ATS and CTS correction factors are at 0% at operating temp.
Keep in mind the purpose of the VE table is to get the ACTUAL air/fuel ratio to match the TARGET air/fuel ratio, not just to get the car to run right. Is this how you are going about this?
Keep us posted... good luck!
Air Temp sensor is in stock location which is in the lower intake manifold, i suspect it's ok @ idle because it reads very close to ambient temp +1/2*
Timing light does match, which brings up another question? It seems as if any more than 30*timing it will detonate, with stock electronics i was running 14*base and comp adds 18=34, and i've run as much as 19 base in the past
Engine is fully warmed up,I also have a 180 t stat, car runs no higher than 185, i was thinking of puttin in a 160, is there any negative affect in doin so?
I'm not sure on the correction of the ATS/CTS, i'll have to check
The actual A/F is within 2%, and is as close as aprx .9% Car idle's best @ 12.5:1, any leaner and it starts to surge
Craig, since i've got your attention, I was wondering is it possible to make a car with FAST start up like stock, every car i've ever seen with DFI or FAST always seems to take noticably longer to start than a stock car. I've asked a few people and they all say "thats the way it is". My company truck 84 E150 van with 284k starts so quicky i dont think the starter even turns 1/4 revolution.
Another point, is that i still have the stock converters on the car, is that a problem?
Is it possible to make a car pass emissions with this setup, I initially though it could be done by leaning it out alot but it surges like crazy when i do that
What parts/vechile are they from to use a knock sensor? I've called around and most places steer me away from the idea?
I'm also thinkin of tryin a 1 bar map, what vechile can i get 1 from @ the local parts store?
Thanks For the replies, this is the sole reason I bought instead of Gen 7
