Running into some confusion on things on cam sync BTDC. It is my opinion that the logged number is based on the time after the crank signal takes place and its reference to the cam precedes cylinder. I am going to experiment changing the cam sync precedes number to see if this effects my cam sync readings. This is the situation
I have installed the cam sync signal physically to sync at approx 80 BTDC based on the balance marks and measurements. XFI is showing cam sync to be 25 BTDC. This is impossible as it is not installed at that position. However, I am going to change the precedes number to #1 instead of #6 and report the new cam sync numbers.
