Fastest Pump Gas / Alky Car...?
Congratulations on the success with the 6466. You're the first guy I've seen that has gotten the combo put together that let's the turbo live up to the hype that it received when it came out.
I also have iron heads.
Thanks bud. It's actually a 6765 journal bearing I picked up off Bison.
For half the price of that 6466
heres another one that needed to be moved up frpm #20 to #18
insane6 10.377 128
List of Fastest Pump Gas/Alky Regals with a 109 block
1. snyderjw1...........................9.623@143.28
2. pacecarta...........................9.815@137.68
3. JC'sGN...............................9.82@137
5. 1985GN............................. 9.91@137
6. Grumpy.............................9.94@138
7. jdsgnx............................... 9.99@134.46
8. RICHIE HIGH PSI..........10.05@133
11. TURBO 6........................10.12@132
12. SloGN.............................10.15@130
13. murphster......................10.19@129
14. J-B Racing......................10.22@136
15. cutt................................10.30@128
16. HiTech6........................10.365@128.51
17. Quik Six........................10.373@131.8
18. insane6.........................10.377@128
19 Super6...........................10.41@128
20. DougsfastZ....................10.42@130
21. turbo6randy.................10.46@131
Someone should update the list and put an Asterix (*) at the end of the time for iron heads designation...
I'm a stroker alum headed pos ........but I'm on a stock throttle body and a single nozzle with small ass tires 255 mt radials it has 67 dbb billet wheel . . But it's a street car that's heavy ...........
Sent from my HTC6500LVW using TurboBuick Mobile mobile app
whats a stroker ? :)
Agreed. I'm going to use this same turbo on my next build, but I haven't see anyone really run it hard yet. Will a 6466 get you over 140mph if run really hard?
Who is running a 6466?
i'll leave JD with his asterix
might as well add who is stroked as theres quite a few that arent
2. pacecarta...........................9.815@137.68 junk iron- 234ci
7. jdsgnx............................... 9.99@134.46 Iron / 231 / 3610 / 71hpq
10. Sydwyndr.......................10.07@133.57 GN1 / 248 / 3665lbs / 70gtq
12. SloGN.............................10.15@130 TA / 249 / 3700 / 67hpq
13. murphster......................10.19@129 gn1 alum -234 ci
I started to make a list on this from the build information but less than half had posted their combo.
Be interesting to see how many have FAST Systems and how many are still chip cars.
Didn't know that. Got you crossed up with a guy on the 6466 thread. Senior moment.
Still running my 6265JB. Engine is currently down and the intake and heads are headed to Champion tomorrow. Several other problems found will be resolved and going to keep the "O" ring set up using FelPro head gaskets. Should make quite a bit more power when we are through.
Still feel like Jack in the Land of Giants.<G>
I was on a chip for my run on the list and Turbonetics CPT70 and over 3600. Now on XFI, DBB 71hpq, 3465, less timing, less boost....
I did see another one to add to the list according to this post (goche4 - 10.20@132): http://www.turbobuick.com/forums/threads/first-full-pass-in-the-gn.401986/page-2#post-3292615
7. jdsgnx............................... 9.98@134.49 Iron / 231 / 3610 / 71hpq
8. RICHIE HIGH PSI...........10.05@133
15. J-B Racing......................10.22@136
17. HiTech6........................10.365@128.51
List of Fastest Pump Gas/Alky Regals with a stage block
1. Robert Wilson...................9.221@146.61
