what is the fastest full weight stock long block TR ? 10.60? what turbo converter?
It was a stock bottom end and 10.29@133.4. Not a stock longblock. Big difference. Touchy question though since most would have at least changed valvesprings and the timing chain for safety reasons. Better question would be stock bottom end and un ported heads with stock cam/head gaskets and fasteners. If someone had a good low mile stock block and cranked it hard for a couple balls out passes with a good converter and mega boost with a HPQ im sure it could make some low 10 sec power for a pass or two.didnt BISON run a 10 teen or something close to that. i remember seeing something about a 140k mile stock unopened long block awhile back.
I no that RJC racing went 8.95 on the stock block
Actually it was Dick Kereny who did it not Jason. I think Jason has only ran in the mid/upper 9's. His car is more a street car running a 200r4 trans, his car is very very nice. Don Cruz has made 2 passes in the 8's, 8.97 and 8.89 if I'm not mistaking at 3550# with a 70mm turbo.
When did that happen?![]()
Some of you guys are MISSING the post!! NOT built to the HILT 109 block.
STOCK LONG BLOCK !!!!
