Finally got a scanmaster please help with numbers
BIGJOE
02mv 445 idle to 850 at wot there has be 0.0 knock threw out all the wot tests.
the rest of the numbers are at idle
AF 06
L8 42
BAT 13.2
INT 120-131
BL 117
CLT 171
AT5 118
R 800-875
TPS .52
IAC 42
CC 32-237
nal 00
AF 06
L8 42
BAT 13.2
INT 120-131
BL 117
CLT 171
AT5 118
R 800-875
TPS .52
IAC 42
CC 32-237
nal 00
What chip do you have? With the key on engine off,what is your TPS number when the throttle is pushed to the floor? What was the ambient air temp ?
are you sure iac should be around 10 at hot idle? the book says factory cars run about 30iac at hot idle with a tps of .30? just curious if thats wrong
i feel dumb ive read the book but im still kinda lost on how to adjust the iac do i unscrew the whole thing..or what? its seriosly confusing me hahahah
its the screw on the throttle body across from the tps sensor .. adjust it to ten at hot idle ..then reset yor tps
check out the pdf link sent above .. scroll down to tps ..iac .. i think page 4 or 5
