First 11 sec pass
ITSAV6
It's my Granny's car!
Haven't tracked my car in probably 5 years. The last time it went 7.6@87 and 12.15@107 with Reds 93 chip and 17#, has 1.6 60ft@6# launch.. I added the Gen2 Translator and Bob's Extreme G chip and a wideband. Even without the wideband tracking set up wot a/f was 11.3 I added a good bit of timing@wot for 2k and have it taper down to 18deg by 3k. Really improved throttle response and spool with my tight converter.
Went yesterday and made 2 passes. went 12.16@114 with a 2.0 60ft and next was 11.78@115 with a 1.7 60ft on 93 octane pump gas and on 255/60/15 MT Street R radials. I know the second pass was 94mph in the 1/8th.
Only suspension mods are F body front sway bar and ATR rear bar. I literally have all the factory installed bushings.
Really good! Was this at south ga motor park or whatever its called down there?
That is the place. Us locals call it "Cecil" because that's the little town it's actually in. We are going back this sat. I will have my Mease slic ic on and boost a pump installed and 100 octane in the tank and at least 20 psi:) I wish my converter wasn't so tight.
If you plan to run 100 the oxy fuel needs more volume.
Just got back from track.1.65 60ft 7.15@96.4 1/8th 11.25@118.4 1/4 7 gal E85 in full tank of 93 Base fuel psi to 50psi and added 5% to the high load on Translator to get my A/F back to 11.3. Made a couple of passes where I remembered to lock the converter in 3rd after it got to 4800 but both those passes I had to pedal for spin at top of 1st. They were 119.2 and 120.6 All passes were at 20psi. Only changes is the Mease SLIC and boost to 20psi and the E85 and volts boosted to 15.9
Need Boost came with us. Richard Lasseter was there with some guys with 2 GS Buicks.
