SignUp Now!From the passenger seat I couldn't tell him to let out quick enough...![]()
K.
An unexpected 30+psi boost, 5+* knock, and alittle lean...K.
Oh, you mean the TSM tune right?
jk, couldn't resist.![]()
Bet it's gonna fly tho.
Patrick
you better get your charging system looked at because your knock was caused by your voltage dropping in the 11's and caused your drop in fuel delivery causing your o2's to drop at this voltage amount frames 512 thru 530
5+* KR at 30+psi. Id be pulling it for a teardown.
So what did it damage, Plugs, what?? Hope it let you slide one time.:wink:
If the 5* KR was truly detonation it wont let you slide at that power level. There is no acceptable amount of detonation at the level he is at.
Yeah bison I see your point. I bet the owner regrets screwing with the wastegate. I can also bet he hit 30psi more than once.
whats his engine mods ? and what stall converter thanks
