You need to try everything. There's no limit to it if you want to get the most out of your partsAs far as the tc goes, just leave the shift points alone? I do play with timing and afr a little with the FAST. Thanks.
BPE2013@hotmail.com
SignUp Now!You need to try everything. There's no limit to it if you want to get the most out of your partsAs far as the tc goes, just leave the shift points alone? I do play with timing and afr a little with the FAST. Thanks.
How do I determine tc slip for the 1/8 th.?
1/8 slip will be higher than 1/4 slip.
It is possible to get 1/8 slip in the single digits but the gearing isn't usually suited well for 1/4 trips.
Thanks for info, Dusty and congratulations on your 4.26.
I lock mine @ 85 it helped my ET on old set up
Edge told me it wont hurt it at my power level
was not much slip at 85 only dropped RPM 150 to 200
1/8 went 91.5 to-92 Et 7.7 to 7.6
1/4 went 112.5- to 114 Et 12 to 11.8
