scot w.
GNSperformance.com
- Feb 19, 2005
This info right from Comp Cams...... as of  11/20/08
PRO PLASMA - The cure for flat tappet camshift worries!
Comp cams has once again proven their leadership by pioneering the use of Pulsed Plasma Nitriding to solve today's flat tappet camshaft durability concerns - A process we've named "Pro Plasma" Nitriding. This proprietary process is performed completly in-house with the most advanced equipment available & extensive testing has Confirmed a 100% increase in surface hardness and lubricity for improved durability.
What is Pro Plasma Nitriding?
Pro Plasma is a patended, 36 hour Nitriding process that uses pulsed nitrogen plasma, in a vacuum controlled inviroment, to embed chains of nitrogen ions into the camshaft surface approximately .008"-.010" deep. This newly fortified outer layer (Not a coating or polish) strengthens the cam shafts lobe surface 100%, reducing the chance of premature lobe wear during the critical initial break-in procedure and well beyond! No shine, Just a proven solution!
Why should you add this process to your next flat tappet camshaft?
Simply put - Peace of mind! The always tightening EPA restrictions on modern motor oils have led to a drastic decrease of key oil additives, which are essential for propper lifter rotation in flat tappet valve trains. Without them, the probability of premature lobe wear, lifter seizure or even complete failure greatly increases. Comp cams Pro Plasma Nitriding is a permanent solution for flat tappet issues! It not only strengthens the contact area between the camshaft lobe and lifter but also increases the surface lubricity through reduced friction.
See a Tech bulletin on Pro Plasma Nitriding-
http://www.compcams.com/information/whatsnew/Files/255.pdf
Watch a Video of the process.- Power Performance TV : COMP Cams Pro Plasma Nitriding Service
Scot W.
Scot W.
  . They cant even get a simple mechanical part like a hydraulic roller lifter to be consistent in QC. Then when you call them they act as if they never heard about the problem. The Comp cam you see in my sig is the last one you will ever see me use from them. This doesnt correct the engineering flaw the Buick engineers made when they mis-located the #3 exhaust either.
