- May 27, 2001
Big Stu said:I'll be in there too hopefully in the next year or so. All it takes it money and persistance...I have plenty of persistance!![]()
Big Stu should do it based on the tutelage of the previous owner!
SignUp Now!Big Stu said:I'll be in there too hopefully in the next year or so. All it takes it money and persistance...I have plenty of persistance!![]()
John Wilde said:Big Stu should do it based on the tutelage of the previous owner!![]()
Lunkan said:ROTFL
You couldn´t resist, could You
It sure was alot of parts, but I don´t think that we´ll be able to use much of it... Take a shot of all parts too.
odell4o8 said:swede, those go on top of the lifter , the springs set in a grove and it is part of the high rev, kit. i have a set of crowler lifters that are offset, and has the alum, sleeves like yours, good luck, oc,
Big Stu said:Looks like a nice parts collection. What struts are on the front of that thing?![]()
The Swede said:...
All to save weight, i lifted the front end with one hand.
Big Stu said:Weldon pumps or aeromotive. Aeromotive makes a belt driven pump which some guys that make 2500+ hp use, seems to work fine for them. I am guessing you will have to run two for the volume that methanol requires?Either way, two banks of 160's is a lot of injectors.
TurboTR said:Hmm... Are you any relation to Magnus Samuelsson? lol
TurboTR
John Wilde said:Here is the mechanical pump that duttweiler speced for our twin turbo small block.
http://www.watermanracing.com/
I will try and get more specific information if you want it.
