Got another frame to Mod and need some input i plan to box and notch the frame and add the control arm braces plus reweld all the seams. I also want to add some tubing between the rear rails to aid the notch now i seen a single tube from rail to rail but i would like to do more i seen a pic somewhere that triangled tubing from the cross tube down to the upper control arm mounts which looked impressive anyone seen or done that?
When welding on the frame if i have it sitting on jack stands do i have to worry about warpage or bowing if i weld some sections at a time or is there another way to do this? Any pics of frame mod's are welcome!
