Vapors or smoke out of the valve cover breathers generally means either a blown head gasket(which shouldn't be the case on a fresh rebuild and not getting into boost yet) or blowby past the rings(which probably aren't seated)...The other one is cracked pistons or holed pistons(which also isn't the case on a fresh motor that hasn't been driven hard)...
If you have the equipment to do it, run a leakdown test on the cylinders and see what kind of readings you are getting...A normal compression test may show good numbers on cranking compression, but a leakdown test will give a better indication of how well the rings are seated(or aren't, in this case)...
I'm getting ready to put my motor together for my 87 T and basically have done the same as you...BUT, I am replacing some unknown brand replacement +.030 cast pistons with TRW/SpeedPro forged, a re-hone
eek: ), a turbo crank to replace the NA crank that was in there, and decked the block(because of a blown NA head gasket that was put on instead of the correct turbo motor head gaskets, didn't want to take a chance on the new gaskets not sealing in the area where the NA gaskets blew and I had no idea how many miles I had on it with the fire ring around the cylinders melting out...Hopefully, I won't have too many blowby problems now(I did have some with the motor before the head gasket completely blew out between cyls #1 and #3)...I had some oil dripping from the valve cover breather for some time before the motor came out of the car...
Good luck and let us know what you find out...
